跳转到主内容
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
40 个问题 查看全部
Weed wacker runs fine but stops as soon as it hits the grass
I have an older model 4 cycle craftsman weed wacker probably around 10 to 12 years old. Have replaced fule line a few times and even the clutch once or twice as well as cleaning the carb here and there but at the end of last year I went to use it and it started fin reved up to full then as soon as it took a load by hitting grass shut off. It then started and reved fine again and did the exact same thing like 5 times in a row. I have a smaller one that I have been using but I have a bunch of attachments I really need the power of the 4 cycle for. Any idea on what could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Sounds like you know your way around it pretty well so probably already checked the obvious issues: carb, fuel line cracks/filter, sparkplug, string length...? Gas cap vent?. Air filter?
完成的
添加一条评论
1个答案
最有帮助的答案
@celenbris You've covered a lot of bases, for sure, but there are a few more things you can check:
  • Replace fuel filter (usually found inside the gas tank, on the fuel line)
  • Completely disassemble the carb and clean in ultrasonic cleaner
  • Check gas cap, as it has to vent the tank. (Try unscrewing the cap a little, to create a gap. If that keeps it running, you know that the vent in the gas cap is plugged and the gas cap needs to be replaced.)
  • Check and clean the spark arrestor screen. They foul easily, and is one of the most common reasons for an engine bogging
Start with those, and let us know how it goes :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anthony sabatino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 106
