跳转到主内容
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Can I replace dark gray display with a silver display?
My dark gray display is damaged. The store doesn’t have the dark gray display in stock but it has the silver display. Is the silver display compatible with the dark gray MacBook Air? I don’t care about the matching optics. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
YES they can do just that
There are no differences apart in the electronics the only difference is the colour:-)
In my opinion I would wait but if you are ready to go ahead I say go for it as it would be unique
If you want it to look normal I would get a nice skin for it
Hopefully this answers your question
这个答案有帮助吗?
得分 2
添加一条评论
If they are the same model, then yes, they would be compatible, regardless of color. Apple would not allow you to do this sort of swap, but the parts are functionally the same so it should still work as a replacement screen regardless. So if the aesthetics don't matter to you, then this shouldn't be an issue.
这个答案有帮助吗?
得分 2
3条评论:
@flannelist great answer as always. Hopefully you are considering to expand on the About page on your profile. That way we all get to learn a little bit about who we all are and what we stand for. Makes it easier to interact and creates a much stronger community :-)
No pressure of course. It's totally up to you.
完成的
@oldturkey03 It's on the agenda :) I've been meaning to do it for ages, but alas. ADHD and an ever changing landscape at work means it keeps getting deprioritized. Maybe that will be my task for the bus ride home tonight.
完成的
@flannelist I totally get that:-) Looking forward to seeing it when it’s up. Bus ride home. How awesome is that! Stay safe
完成的
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 154
