跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
Touchpad swipe functions not working after shell swap
Hello, I swapped my entire shell and wired up a extremeRate backbutton set. Everything is functional on the controller except the swipe function. The button input from the touchpad works fine, but I'm not sure why the swipe has gone away? Could the board not be completely stuck to the replacement pad and not getting a correct input?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I believe this may be a problem of the pad not making contact with the board like you mentioned. So I would take it back apart and make sure that the two are getting a good connection, make sure to tighten any screws so that there is a good connection.
这个答案有帮助吗?
得分 0
5条评论:
Tried this when I go home. I got it all apart heated it back up and left a heavy object on it. Still no dice, I think the ExtremeRate replacement touchpad is just to thick.
完成的
I see, I suppose it may just be a bad a touchpad.
完成的
I have the same issue multiple controllers. Doubt I have two bad touchpads. Both worked prior to mod
完成的
I have the same issue on two controllers, no touch input but the button press works. I haven't replaced any original parts of the Dualsenses, but kitbashed a red and black controller (this looks really cool, believe me!). So now the black touch pad is connected to the red motherboard and visa versa. I think this is the problem, but I'm not sure until I take both controllers entirely apart again and reassemble everything. Both controllers are brand new and I haven't 'opened' the touch pad. If anyone hete has any more know how of the hardware, please let me know!
完成的
The touch no longer works once you replace the touchpad using the extremerate full shell swap. I know this is a year late but for anyone else who sees this.
完成的
添加一条评论
Did anyone figure out what was wrong? I have 2 controllers with this issue. One of them hasn't even had parts replaced. The ribon cables seem fine.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
abranscome12 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 91
总计 1,926
