跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Is this a logic board problem?
Hi, ive been having problems with my iPhone 7. It's been having problems with connecting the lightning cable, and battery has been going flat quicky. I can always get it to charge by pulling out the cable, putting it back in, flipping it etc, and it will always work well with a new cable, but somehow I seem to go through a lot of cables quite quickly. They wear out or something.
Naturally, I thought the fix was that I need a new battery and charger port assembly, but before buying the parts, I have opened the phone, and there looks like there has been heat damage or something to the logic board. I was hoping the good people here would look at the photos and be able to tell me if it's a logic board problem or if it's the battery and charger port. Maybe it's a combination...
Anyways, here's the photos.
Thanks for any help. I figure if it's not the logic board, it's worth attempting a fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Could you take a look at your battery again, does it appear to be bulging at all?
完成的
I don't think so. Looks pretty flat
完成的
Image added (for the battery)
完成的
添加一条评论
1个答案
If the board looks like that when you open it the first time, someone else has been messing with it.
Judging by the amount of dirt inside a supposedly water resistant phone, someone definitely messed with it before you own it.
The damage on the cable is unlikely to be caused by the board, it looks like corrosion caused by moisture.
这个答案有帮助吗?
得分 0
5条评论:
Thanks for the answer. I had the screen replaced a while ago.
Do you think the apparent damage to the logic board is water damage?
Can't really comment on the corrosion, I don't really know. but the damage seems to happen to certain pins and not the whole cable head
完成的
Have you tried cleaning your charging port with a sewing needle?
You will be surprised by the amount of dirt in there!
As for the battery draining ,the iPhone 7 series is getting to a age where there battery’s are going to need replaced
完成的
@Alexander There is no apparent board damage other than the torn graphite sheet. You can't see most of the board damage unless it is major mechanical damage.
For the cable pin damage. Moisture and electricity combined is required to produce such damage. Only those pins have electricity therefore only they are damaged.
完成的
Thanks guys.
@hellomacos. Yeah Ive done that. No good results really.
@tom chai. Thanks! Sounds like it's worth giving it a try. I think I will
完成的
Ah that no good is ,usualy that’s what I found works:-)
完成的
添加一条评论
添加你的答案
Alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 227
