Display gone red along with dead pixels and flickering.
My display has turned red. The lower part of the screen is flickering at a very high rate. Also, there is a patch of dead pixels on the left bottom edge of the screen. How do I fix it??
Hi
I usually work on apple products but I can try and help you with this
Here’s what to try:
Try plugging it in to a external monitor and seeing if it does the same thing if it does it will need to be further tested ,however if the external monitor looks normal you may need to replace your laptops screen
If you can provide me with photos I will give me a better idea of the issue but it’s most likely what o talked about above
这个答案有帮助吗?
Well I am not an expert on this but this might help you.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 33
总计 898
2条评论
RANSOM just to verify, your display is a Dell E2310H? Post some pictures with your QUESTION of what this all looks like. Right now it sounds like a bad panel but we'll have to see. 在已经存在的问题里加入图片
由 oldturkey03 完成的
Hy may display a lince showing automatically and black dots because monitar dad is 1 year so help me a clear bugs
由 Dell 完成的
