24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
Rejekted Records @rejektedrecords
声誉积分: 1
发帖于: 2022年5月30日
Hey Team, I have the same issue - MPB 2019 2-port ..
When I connect my Apple Cinema Display 24" ... the flickering goes mental ...
Tried every configuration. still no luck
这是一个好问题吗?
5条评论:
@Rejekted Records you've checked your power supply? what else have you checked?
由 oldturkey03 完成的 2022年5月30日
@oldturkey03 its the normal AC plug ... changed that even .. still not working ...
It was working normal, then one day ... just like that it stopped ... running Mojave because of plugins ...
由 Rejekted Records 完成的 2022年5月30日
@Rejekted Records are you using any kind of adapter in between? Your display is a A1081?
@oldturkey03 - He needs adapter to convert the display signal from the TB3 (USB-C) to Mini DisplayPort on the 24" LED Cinema Display.
@Rejekted Records - What is the adapter (hub?) you are using?
Also, what is your external displays prefs setting? Possible Resolutions: 1920 by 1200, 1280 by 800, or 1024 by 640 pixels
由 DanJ 完成的 2022年5月30日
@Rejected Records connect your monitor to a device that will not require any adapters and I am certain it will display properly. The issues seems to arise from the conversion from USB-C to Mini Display
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 158
由 oldturkey03 完成的
由 oldturkey03 完成的
由 DanJ 完成的
由 oldturkey03 完成的
