Why won't my Fitbit charge?
All of a sudden (after several months of use), it won't charge when I put it on the charger. Keeps on saying "Critical - 0%." What can I do besides put it on the charger?
Don't worry if your Fitbit Luxe is not charging. You should try the methods below:
这个答案有帮助吗?
I was facing this issue too and now get my Fitbit working fine.
here are the steps that I was tried to fix it:
这个答案有帮助吗?
Allison Huettner double check your charger and your charging cable. Make sure that those are in working condition. Check the charging port make sure it is not obstructed or otherwise clogged, dirty etc.. If all that is in good working order then there is the possibility that this is a bad charging port, bad battery or logic board issue. We will need to know the exact model Fitbit you have for any of those repairs.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 56
过去 30 天: 181
总计 5,753
