跳转到主内容
Repair information, service help, and troubleshooting/diagnostics guides for Bosch refrigerators.
Bosch Side by Side Fridge Freezer E 47 code
We've been troubleshooting a leak in our Bosch side by side fridge freezer for a while (model number KAD62V40GB/13) which we finally found was a blocked drain pipe for the excess water from the freezer, we've cleared the blockage, put the freezer back together and it's all working as expected, except for the fact that the front display is now showing E 47. Usually it would just display the temperature figures for the freezer and fridge (note these are not actual readings just what they should be). The fridge freezer appears to be working perfectly normally.
So I've no idea what this code means, Google isn't helping me and Bosch have been particularly unhelpful by not telling us what it means just that it needs and engineer.
Does anyone have any idea what the E 47 code means in Bosch Fridge Freezer speak?
Thanks in advance
Claire
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Claire,
Have you tried to reset the refrigerator? Unplug for 5 minutes. If that don't clear the error codes try a hard reset by unugging for 30-45 minutes, will restore to factory settings.
https://smarthomeowl.com/how-to-reset-bo...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Claire Davison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 814
