跳转到主内容
Some things just don't quite fit in.
253 个问题 查看全部
Why won't the Philips PhotoFrame turn on?
== How do I fix this problem?==
I was given a Philips PhotoFrame
Model No.:8FF2FPW/37
When I plug the digital photoframe into the outlet and push the power button it does not turn on, the screen remains black.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Have you checked the batteries?
完成的
Besides the batteries, have you checked your adapter to make sure you have output?
完成的
I have the same problem but can’t do any upgrades because can’t turn it on . Any suggestions?
完成的
添加一条评论
2个答案
已选择的解决方案
Needs a firmware upgrade - Your phtoframe has shut down into a power save mode as yo umay not have used it for a long time. Upgrades on the Phillips web site
这个答案有帮助吗?
得分 3
1条评论:
how do I upgrade?
完成的
添加一条评论
Can't upgrade if you don't have power. Drivers wont install besides that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 25
总计 9,371
