跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Screen flickering and then screen goes black
My 2016 15” MacBook Pro's screen flickers and then screen goes black. Does anyone found a solution for this. I'm told to replace the screen for 60INR by the service centre.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you have the answer? I have same issue will this fix my MBP 15” 2016 Touch Bar.
完成的
添加一条评论
2个答案
The only way is to have it repaired, but it will cost over 700 USD and the technician might not even know what's the problem. Therefore, I would recommend trade in your laptop for a 700 dollar for Apple gift card and upgrade to a new MacBook Pro with M1 Chip. That's what I did to solve this issue.
这个答案有帮助吗?
得分 0
添加一条评论
Hi!
If you are comfortable with opening your MBP and know how to do micro soldering then you can try to repair the backlight cable which can cause the issue if it breaks. The cable in the 2016 & 2017 models were too short and every time you open the screen the backlight & camera cable wears out. Since Apple realized in 2018 that they messed up, they quietly changed the length on the 2018+ models. This cable can not be removed from the screen, that's why it is such a pain to fix.
If you get the screen replaced, I am pretty sure they put in a display with a longer cable.
Here is a link to the cable:
MacBook Pro Retina (2016-2019) Display Backlight Cables
MacBook Pro Retina (2016-2019) Display Backlight Cables图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dr. S.R. SHANMUGAVEL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 52
总计 1,116
