跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
430 个问题 查看全部
XBOX 360 controller pad came off - axis not working
Hello there,
while I replaced the potentiometers on my XBOX 360 controllers (wireless), I made a mistake by heating it up too much. It looks like the wire lane connecting the pin with some part of the board is messed up. Now the X-Axis on my right stick isn't working anymore. I tried replacing it with another potentiometer but got the same result. Looks like I destroyed the connection of one of the pins. I already tried to find a solder joint so I can just use a small cable to get it back working, but I can't find the neccessary joint.
I own another wireless controller which has a slightly different layout and is working fine, however I also couldn't find a spot where the soldering joint connects on the board.
Edit: This is a PCB image of the type of controller I'm using
https://www.acidmods.com/forum/index.php...
Is there any way to connect the lane for the red X without having to solder it directly to the chip?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Unfortunately, you need to solder it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 69
