跳转到主内容
Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
39 个问题 查看全部
How similar is the repair process of the iPad 8 to the iPad 7?
Currently, I am attempting to find a repair guide for the iPad 8 but all I'm finding is the guides for the iPad 7. I'm just curious as to how similar the repair process is for the iPad 8 compared to the iPad 7.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
What are you trying to repair, specifically?
完成的
@flannelist Primary the digitizer, screen, and the battery. Although, I'm just asking in general how similar the process is.
完成的
添加一条评论
2个答案
已选择的解决方案
As far as I can tell, the processes for the bog standard repairs are going to be nigh identical between the two. The board layout is extremely similar, all the connectors are in the same place. Processes may be EXACTLY the same, but I don't have an 8 on hand and I cannot seem to find any specific pictures of the iPad 8 internal layout. But I would expect it to be a translatable experience from one to the other. Even iPad 6 to iPad 7 is very very similar, aside from a few quirks and the obvious change is display size.
这个答案有帮助吗?
得分 4
1条评论:
iPad 7 and 8 are almost 100% identical, we haven't looked under the microscopic to compare board components, I think they just upgraded CPU on 8th gen. Replaceable parts like digitizer, LCD, battery, home button, cameras, audio jack, lightning port, etc., are exactly the same as 7th gen.
完成的
添加一条评论
They are the same design, so the repair process is about the same.
这个答案有帮助吗?
得分 2
2条评论:
When you say it is "about the same" do you mean it's exactly 1:1, or is there a step or two that is modified slightly?
完成的
@jmehnert They are identical as @flannelist said.
完成的
添加一条评论
添加你的答案
Jacob Mehnert 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 470
