跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
142 个问题 查看全部
Replacing display, should I replace frame as well?
I have a Samsung Galaxy S9 and I'm planning on replacing the display as the one currently on the phone is cracked and doesn't receive touch input on most of the screen surface area.
On the guide it is mentioned that if the frame itself is damaged/dented, it could lead to the new display damaged as well. The S9 I'm going to be working on has had some damage and I'm hoping if anyone here could give me some advice on whether I should go ahead without getting a new frame or replacing the frame and the screen.
I've included photos of the display and frame with and without the screen being on.
Display images:
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
This would make the repair easier, but more expensive. Also, if you only replace the display, you will need to make sure you have enough spare adhesive. Display replacement guide: 三星 Galaxy S9 屏幕更换
这个答案有帮助吗?
得分 2
7条评论:
So would just replacing the display be alright?
Do you think that the dented frame could interfere with the display and possibly cause damage again?
I don't mind if it's more difficult, but I would like to keep the price cheap. The main thing for me is making sure that the display has no chances of breaking again, the screen on its own is pretty pricey!
完成的
@jermia Yes, this would be totally fine. You will need to be very careful to prevent damage.
完成的
@guardian10 Hey thanks for the advice! In what aspect do you mean to be careful? Do you mean in general during the whole process or just making sure that I'm careful for a particular step?
完成的
Also the frame dents should be straightened out with pliers or a similar tool.
完成的
@jermia The whole process
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 999
