跳转到主内容
bottom of case warped
2018 MBPro A1989 - the bottom of the case is warped but my battery seems good. Holds a charge and MBP functions normally. I've seen articles about batteries swelling and needing replacement. How can i be sure what i need to fix this?
Update (04/27/2022)
Hi Mayer, see screenshot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Do you have a Pentalobe P5 screwdriver?
完成的
@andrewsawesome hi Andrew I do but not with me as I’m away from home on business. What do u think I should do?
完成的
Hi Mayer, see screenshot. [image|2643983]
完成的
添加一条评论
2个答案
已选择的解决方案
I would use the MacBook until the battery is dead, and then open it up and replace the battery. It is very likely that the battery is swollen, and if it is, it shouldn't be used. Using the battery until it's dead discharges it so that it's safer to remove.
这个答案有帮助吗?
得分 1
3条评论:
I have noticed that since removing AC power this morning about 2-3 hours ago, it does seem to be discharging much quicker than i remember (26% now). At home i always have the power adapter connected, lid closed and use external monitors.
Assuming its the battery, does this mean my case is forever warped too?
完成的
@nealsil Take a look at Dan's comment on the warranty exception. As for the case, you can use a hammer, piece of wood, and a microfiber cloth. Place the piece of wood under the warped area, then use the hammer to flatten down the warped area. If that doesn't work, you can get a MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case from iFixit.
完成的
Thanks very much for all the advice. I'll do some more investigation and report back what i end up needing to do.
完成的
添加一条评论
最有帮助的答案
Let's take a better look at that batteries health. Please download and run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
这个答案有帮助吗?
得分 2
1条评论:
Battery is in trouble! Technically your battery should last very close to 1,000 cycles yours is not even past 100!
You should visit an Apple Store for the battery to be replaced by them under a warranty exception!
完成的
添加一条评论
添加你的答案
Neal Silverman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 460
