跳转到主内容
加入维修社区 - 创建账户
2.6 GHz 双核 Intel Core i5 处理器(Turbo Boost 最高可达 3.2 GHz),配备 3 MB 共享三级缓存。发布于 2013 年 2 月 13 日。
wifi and bluetooth not working
my wifi and bluetooth don't work after replace the battery
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I would reseat the I/O data cable which connects the I/O board (with the Airport board) to your main logic board often I find the cable connection is the issue, you may need to replace the cable MacBook Pro 13" Retina Display Early 2013 I/O 板数据线更换 if the Airport board is properly seated and the antenna cables are in good shape.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
First thing I would check is to make sure that the antennas are plugged in properly. The order of the antenna cables is kind of weird (to me anyways). Step 10 of this guide tells you which one goes where.
MacBook Pro 13" Retina Display Early 2013 AirPort 卡更换
I would also make sure the cables between the I/O board and the logic board are seated properly, since that's what carries the signals for bluetooth and wifi over.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
MAXIMO MEYRELES 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 670
