跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement
你所需要的
  1. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    添加评论
  2. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
    询问修复机器人
    添加评论
  3. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    询问修复机器人
    添加评论
  4. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
    添加评论
  5. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    添加评论
  6. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    添加评论
  7. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 7 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    添加评论
  8. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
    询问修复机器人
    添加评论
  9. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, Battery Contact Board: 步骤 9 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, Battery Contact Board: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    添加评论
  10. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, I/O Board Data Cable: 步骤 10 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement, I/O Board Data Cable: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    添加评论
  11. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 11 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 11 中的图像 2,2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    添加评论
  12. MacBook Pro 13" Retina Display Early 2013 I/O Board Data Cable Replacement: 步骤 12 中的图像 1,1
    • Lift and remove the I/O board data cable from the MacBook Pro.
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,675 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,230篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 44
总计 4,116
