跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5S "press home to upgrade" unusual issue
A long while back I broke my old iPhone 5S, and I just got around to fixing it about a week ago. It went well, but now I'm stuck on another problem, one I haven't found a fix for yet. The phone was about to be upgraded to the newest iOS version before it got broken, and I don't remember the passcode, which I need in order to continue with the upgrade. Whenever I plug it into my computer, it isn't recognized by it. The data on the phone is what matters to me, so I can't just wipe it and start over. Any and all help would be incredibly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
UPDATE: It can connect to a computer but only in recovery mode. Updated via iTunes successfully but still stuck on the passcode requirement,
完成的
添加一条评论
2个答案
最有帮助的答案
how long ago did it break as the battery might not be charging, if it shows anything on the screen try a different cable or charge port
这个答案有帮助吗?
得分 1
1条评论:
I am able to charge the battery just fine, the hardware is fine as far as I can tell. It's the software that is the issue, as it's in the middle of an update. I can try with different cables and USB ports, but my newer phone can connect to my computer just fine with the same cable and same USB port. It's possible the lightning charger port replacement part was damaged in some way, to where it can charge the phone but not access the information on the phone, but I'm not sure.
完成的
添加一条评论
If you have a windows pc try downloading the iTunes app for windows and then connecting the phone to your computer.
the phone should show up in the app. Try backing up from there.
这个答案有帮助吗?
得分 0
3条评论:
he said it isnt recognised by the computer
完成的
@tech_ni Sometimes it only shows up in the iTunes app.
I got a boot looping 5s once and it only showed up in the app, the pc didn't recognize it.
完成的
I have the iTunes app already downloaded, and when connected to the computer via a charging cable to a USB port, the phone itself isn't recognized by my computer or iTunes. I could try this with a different computer and or a different charging cable and such, but my new phone can connect to my computer with the same cable and USB port just fine, so I didn't initially think to try that. The moment I'm able to access the data though, I can back up the phone and dump the data from it onto a phone that isn't updating, hopefully.
完成的
添加一条评论
添加你的答案
Raven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 56
