跳转到主内容
加入维修社区 - 创建账户
Charging port doesn't work
Hello! When the device is plugged in via the micro-USB port, the device doesn't charge. Does anyone have any experience replacing the port, or know of any other ways to fix this issue? Thanks in advance.
For info, I have tried several cables, as well as connecting to the mains and to a laptop but in no case can the device be turned on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @es2k6
Here's a video that shows what to try that may help.
这个答案有帮助吗?
得分 3
2条评论:
Hi. Thanks for the video. I just tried that, as well as updating the firmware with the bose updater. The device is recognised by the computer but still no way of turning the device on.
由完成的 分享
@es2k6
Here's a video that shows how to disassemble the speaker. This should give you access to the charge port and if you have a DMM (digital multimeter) you can check if the port is OK electrically and you can also visually check for any problems on the motherboard
After that it becomes harder as Bose doesn't release any schematics.
由完成的 分享
添加一条评论
添加你的答案
E S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 47
总计 3,275
