跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Sony ps4 can’t connect to tv
Hi my console won’t connect and we have tried 2 cables and 2 tvs.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Chris,
Have you checked your pins aren't bent or anything?
Have you tried replacing the HDMI port? (If your skilled otherwise don't)
Did this just randomly happen or did something lead up to this?
If all of the above are true (Randomly happened, no bent pins) you like have the BLOD or WLOD (Aka the permanently unfixable problem). You can try booting into safe mode by holding the button until you hear 2 beeps. What can be attempted next is to tighten down some washers and see if that will fix it. If not then pull out the hard drive, buy a cheap SATA to USB cable and get your data off it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
