How do I get a stuck disc out.
My wii will not turn on and it has a stuck disc inside it, how do i get it out.
Update (09/16/2015)
First, lift open the GCN port and take off that piece of the faceplate. Unscrew the little black philips screws (i believe there are 9). that piece will come off . Under the wii there are white bumps that you can pry off as well certain stickers. check a guide to see where as I'm currently at school. these are slightly larger philips screws. there will be the same instance on the side of the wii that you can lay it on where you can use a spludger except these require a deep triwing screwdriver. Open these up and you will see extra triwings on the face plate of the wii. You can manually trip the sensor and eject the disc.
13条评论
it doesnt work plx help :(
由 gerardo 完成的 分享
gerardo, what does not work? what have you tried?
由 oldturkey03 完成的 分享
How to get the Wii to sence the disc
由 Domnic Paccione 完成的 分享
how to fix stuck disc in wii u
由 elyossiahaya 完成的 分享
The disc is wasn't come out
由 Paul Kim 完成的 分享
显示更多的8条评论
