跳转到主内容
加入维修社区 - 创建账户
于 2018 年 11 月作为 iPad Pro 系列的成员发布。型号为 A1980。
Where can I get a replacement for the front glass?
Not the display panel or touchscreen, the glass ontop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
The screen and digitizer are fused together on this model of iPad, meaning you can't separate them (without special tools) or buy them separately. You can get a new display here.
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display. This part is compatible with an iPad Pro 11" 1st Gen (2018) or 2nd Gen (2020) tablet.图片
产品
iPad Pro 11" (2018, 2020) Screen
$189.99
这个答案有帮助吗?
得分 7
添加一条评论
Fun Fact: The display assembly for this iPad uses the same connections from the display to the logic board in (at least) the first three versions of the 11 inch iPad Pro. Now that, of course, does not apply to the quality. If you’re looking to buy an aftermarket replacement for the third generation screen and you opt to buy one for the second generation screen, there will likely be some minor differences in regards to image quality and brightness. Here is a link to a display I’ve used for an iPad Pro -11inch (1st gen) display assembly replacement. The repair was straightforward and simple and resulted in no change in functionality in regards to the touch screen or the display quality.
这个答案有帮助吗?
得分 0
添加一条评论
So its possibel to put a A2230 Display on a Ipad Model A1980 ?
这个答案有帮助吗?
得分 0
3条评论:
Correct. I’ve done it without issue. Some users may notice a difference in sharpness or tint in the display but that is often a result of the quality of the display replacement purchased i.e. not a technical issue.
完成的
Ok Nice i bought a pulled good Display now 👍
I hope everything goes alright 🙂
完成的
How hard is it to replace the face recognition hardware?
完成的
添加一条评论
添加你的答案
dsi lite 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 66
总计 3,830
