跳转到主内容
加入维修社区 - 创建账户
PlayStation Vita 的第二代产品,PCH-2000 系列,通常被称为 PS Vita Slim 或 PS Vita 2000。该设备于 2013 年秋季在日本宣布,并于 2014 年 5 月在北美发布。 它被定为一款掌上娱乐设备。支持 :: Wi-Fi、PlayStation Now、PlayStation Network / Plus、蓝牙。型号:PCH-2001。
green light when power button pressed, but only get a black screen
So I've been having this problem for about 4-5 months now and i'm not sure what to do anymore, I've unplugged everything and made sure that every single wire is back in it's place, and when I go to boot it into safe mode I only get a black screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hey i have the same problem, did you managed to fix it up?
Some said it's bricked, the hardware could be OK, the problem is inside the emmc, probably the firmware getting corrupted
I stumbled upon on twitter, someone found the way to unbrick it by using some kind of special JIG.. I hope they gonna make some tutorialsnin the future on how to unbrick it
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi Gavin! To be honest, this is most likely a motherboard issue. Some PSP's are showing the same issue. I only had this once, as I disassembled the PSP, a IC came clean off the motherboard (can't remember which IC came off). I recommend to open it up and check what's wrong and reball (solder) it. Or replace the motherboard (this is more expensive).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gavin K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 30
总计 1,762
