跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
SSD not recognized by MacOS Recovery
Hello
My OWC SSD is not recognized by MacOS Recovery Disk Utility in my 2013 Macbook Air.
I carried out the Mac OS High Sierra update and successfully used the SSD for about a year. Then I think I did something wrong during a factory reset, and the drive is no longer recognized. Is there some way to send it out to OWC to get it reconditioned?
Otherwise I will see whether this procedure works.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you mayer and jack labred for your responses. I will update when I can get to it this week!
完成的
添加一条评论
2个答案
已选择的解决方案
Boot the machine up from an external source Mac and see if you can run Disk Utilities from it. If you don't have one, phone a friend with a Mac and use Target Mode.
这个答案有帮助吗?
得分 1
1条评论:
Success!!! I finally have mac os running off my newer OWC drive in my 2013 MBA.
It took a lot of tries. The trick was to get High Sierra or later an external USB. This allowed me to "see" the OWC drive in recovery mode and apply "reinstall mac os" to it.
Next time I want to wipe the OWC I will have to go through this mess again :/
完成的
添加一条评论
I think it's better to start with: boot your Mac while holding [Command + R].
Select Disk Utility and see if you can mount it this way.
Open Disk Utility, click View in the menu bar, and select Show all devices. You should now see your SSD drive listed above Macintosh HD and Macintosh HD Data volumes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave Dei 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 903
