跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
Where to place optical fan sensor on an SSD/Optibay adapter.
My optical fan rpm's are going over 2500 since I installed an SSD in the dvd superdrive slot. I got the adapter from ifixit, but not sure where to put the sensor. Right now, i've got it in roughly the same area it was with the dvd drive, but I think it's running way too hot/fast. Any ideas to get that fan to calm down??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Here's an installation of a SSD in a iMac. Note the placement of the temperature sensors.
http://www.thatsiebguy.com/2009/10/iMac-...
If this does not fix the problems then we need to look at fans control resets
这个答案有帮助吗?
得分 1
3条评论:
An SSD drive should run much cooler than a standard drive as there are no moving parts.
完成的
Here's where to download a fan conrtol for the iMac: http://www.macupdate.com/info.php/id/230...
完成的
That installation is using an SSD to replace the main HDD. My installation replaces the DVD superdrive. Any knowledge where the coolest place on that side of the iMac is to place the sensor?
完成的
添加一条评论
添加你的答案
hellohogo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 3,438
