跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15 Gaming 7577 发布于 2017 年,是一款配备 15 英寸屏幕的游戏本。它搭载了第七代 Intel Core 处理器和 Nvidia 显卡。
Some Buttons don't always work.
On my keyboard there are some buttons that don't work properly. Sometimes they work and sometimes they don't.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi,
Are they always the same ones or different ones every time?
Have any liquids be spilled on the keyboard at all?
由完成的
Did you clean it?
由完成的
Yes it always the same and no there's no liquid got into it
由完成的
I don't know how to clean my keyboard from inside
由完成的
添加一条评论
1个答案
已选择的解决方案
I would try cleaning underneath your key caps and see if you can get your keyboard to function afterwords. The best way to do this is to remove the key caps from the keyboard itself. There is a guide on how to do this that I will link here.
I would also check to see if the ribbon cable that connects the keyboard to the logic board is seated correctly and is not damaged (I.e. any creases in the cable). If none of that works, it could be that the switches for the keys are damaged in some way, which means you would need to replace the keyboard.
Definitely try to clean the board first, and make sure that the cable is good first before looking for the replacement.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your reply I will try this now
由完成的
添加一条评论
添加你的答案
emad ayad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 654
