跳转到主内容
加入维修社区 - 创建账户
Guides and repair information for KitchenAid mixers.
Mixer won't turn on. Sometimes if I give it a tap it will turn on
Sometimes its a toss of a coin if it turns on when I plug it in. Sometimes if I give a tap it will turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
We have the problem too any answers what needs to be fixed?
完成的
添加一条评论
1个答案
Did you review questions reated to KitchenAid Mixers? If your question is unanswered then you'll have to examine wiring from plug to main power switch with a multimeter checking for continuity on both wires to the switch.
这个答案有帮助吗?
得分 0
1条评论:
Can't find any fault in the posted answer, and would have inferred from the description, that you're dealing with a 1) loose connection or 2) a broken wire, and that the physical motion of 'tapping' causes the connection/wire to complete the power circuit - and the motor is energized. A continuity check of the power cord connection/contacts, would be the first place I would check/test.
完成的
添加一条评论
添加你的答案
Esteban Martinez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 193
