跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
Dead battery needing manually charged
Does anyone know how to charge a dead lithium battery with another battery as I have a iPod that has a severely undervolting problem and I need to manually put charge into it
Any known methods
Any help will be greatly appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The only method would be to wire positive to positive and negative to negative of both batteries. In theory 2 working batteries should balance their power until it gets even, but if you have one dead battery it may not work. However, unless you know for sure the dead battery is not internally shorted or deteriorated, I would avoid playing with lithium batteries, as they have the bad habit to catch fire when things go wrong.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the advise
Il avoid doing it and buy a new one
Thanks! :D
完成的
添加一条评论
添加你的答案
HelloMacOS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 32
