跳转到主内容
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16 个问题 查看全部
Why are my rear tires locked all of a sudden?
I'm having the same problem if anyone can answer.. I have a bad wheel barring and the back all of a sudden locked up and you can hear the gears griding when you try and move it.. my mom's boyfriend said I need a new rear end.. is there anything else it could be where I didn't have to buy an entire rear end?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sorry this isn't the answer but a comment.
I remember from somewhere that the 4Runner has a senser that will normaly engage the locks if the car is in need of extra traction.
If this is so, you might want to look into fix/replacing the senser unit/controller. But first try ungluging the wires to the RR lock switch as this might be faulty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashley Dickinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 35
