跳转到主内容
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
13 个问题 查看全部
I hibernated my Inspiron and now it does not power back on
Hi All,
My Dell Inspiron is a fairly vanilla one with one exception that I replaced the factory provided hard drive with a WD Blue SSD. It had worked flawlessly since almost 6 months. But, this last time, instead of turning it off, I hibernated it and now it is plain dead. The laptop does not show any power even with battery and power adapter attached and it simply fails to show any life.
Not sure what has broken inside it and I even tried removing the battery and help the power button for a few seconds to drain the components of power as was suggested on a few blocks but to no avail.
If you have any idea on what I can do, please let me know. I am pretty sure there is nothing that could have short the motherboard but I could be wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Disconnect both the primary and CMOS batteries, and hold the power button for 1 minute, and try again but turn the laptop on before reinstalling either battery; that sometimes helps and if the CMOS battery is dead then it's easy to tell that way. For some annoying reason, some Dell laptops from the 8th gen era inherited the E7440's CMOS battery voltage sensitivity nightmares. However, disconnecting and reconnecting it (as well as the primary battery, to make sure the system is drained, and the CMOS RAM will be defaulted) often quickly fixes the problem. I've even seen 7490's get sold "as-is" due to this issue - which is why I have a $150 7490 with the 8350U/FHD LG IPS LCD :-). No mine isn't the top spec edition (that's a 4K IPS Touch/i7-8650U/32GB RAM/biggest SSD you can squeeze in it type, these are available BUT are rare) but I came from a bum with a dirty past (active lease where the machine was suspect, with liquid damage. I took what I could at that time.
Yes, I have seen 768p BOE TN ones (I have one as a throwaway with the 8250U) machines, but most of them either have the LG IPS LCD, or the BOE IPS LCD (both are good, but LG is WAY better).
The permanent fix to this problem is a new CMOS battery, especially if it tests at 2.5V or lower (use a cheap multimeter, even a cheapo one from Walmart will work to check these batteries as they're low voltage). Follow this guide to open up the laptop to get to the CMOS battery. On yours if it's dead, you can run out to any store that sells the bare battery and quickly purchase a new one, since there are no leads on this laptop. Even then, your battery is so cheap it wouldn't hurt to just change it to ensure its mitigated. I consider it a consumable item like the primary battery once the computers known to have this problem enter the hands of DIYers at Walmart special prices, especially once the R2 facilities begin selling them off without SSDs.
Dell Inspiron 15 3567 Battery图片
指南
Dell Inspiron 15 3567 Battery Replacement
难度:
非常容易
10 - 45 seconds
Dell Inspiron 15 3567 Memory Module图片
指南
Dell Inspiron 15 3567 Memory Module Replacement
难度:
简单
1 - 3 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abhishek Kapadia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 241
