跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
Need Help Fixing PS4 Optical Drive
So I have this ps4 CUH-1115a that I’ve almost totally fixed, works great EXCEPT for the optical drive(chip size BDP-025). It doesn’t accept discs, it’s almost like the optical drive is OFF when the rest of the console works fine. Eject button doesn’t work or make sounds like the power button does. The rollers are in place, I cleaned it out, the disc shield is down, the switches on the laser board aren’t stuck, the plastic tray is moving freely as it should, I took it apart and put it back together, there’s absolutely no visible reason whatsoever why it’s not working. The console doesn’t give me any sort of indication saying that there’s something wrong with it. I’m thinking it’s maybe the laser deck, but if that’s not it, then I’m totally out of ideas. Suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hey Brendan,
I think maybe one of the chips might be fried or the power could be not reaching it.
If ur skilled or it’s power: Check the connections in the ribbon cables and ensure the locking tabs are sealed. If ur skilled then u can replace the chips
If ur not skilled in microsoldering: Unfortunately your SOL out of luck there’s not much i can do maybe someone else can help.
IMPORTANT NOTICE:
From Sunday Aus to Friday AUS, i will be unavailable as i am camping then.
这个答案有帮助吗?
得分 0
2条评论:
Yes, all of the ribbon cables are exactly where they should be and clipped in. I hope to god I don’t need to solder anything, I haven’t done it a day in my life yet.
完成的
Oof. I mean if u can get the data off of this, transplant it to somewhere safe and replace it, u could use this console as a parts and/or practice console for microsoldering :) Means it's not (AKA not in landfill) ewaste.
完成的
添加一条评论
添加你的答案
Brendan King 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 237
