跳转到主内容
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
How to reset the anti theft system
How to reset your anti theft system in a 2001 Grand jeep Cherokee Laredo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
6条评论
Did you review previous questions with answers related to your Grand Cherokee, the box on the right?
完成的
Mine wont start at all. Battery ok. It's 2021 Jeep Rubicon. Cant shift out of park etc
完成的
This did not work on my 2002 jeep liberty sport.
完成的
This doesn’t work on 08 Wranglers
完成的
Didn't work on my 2004 jeep grand cherokee
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
Step 1
Enter your Jeep and press the Lock button on your keyless remote five times in 10 seconds.
Step 2
Insert your key into the car's ignition, turn it to the "Run" position and wait for the car's chimes to stop.
Step 3
Press and hold the "Unlock" button on your remote, and then press and hold the "Panic" button while still holding "Unlock." Hold both buttons together for one second and release.
Step 4
Wait for a chime to sound and press and release the "Lock" and "Unlock" buttons on your remote.
Press and release the "Lock" button by itself and wait for the car's chimes to sound again to indicate successful resetting. Remove the key from the ignition when you are done to finish the procedure.
这个答案有帮助吗?
得分 5
17条评论:
Will this work if the jeep stopped recognizing the key?
完成的
which button is the"panic
' button?
完成的
I tried the above procedure it does not work is there any other options
完成的
it did not work on my 2005 Jeep Liberty nothing works on it I've tried every thing out there somebody help!!
完成的
显示更多的12条评论
添加一条评论
2004 jeep grand Cherokee laredo don't have key fobs. How do I disable it?
这个答案有帮助吗?
得分 0
添加一条评论
Replaced pcm programmed to ignore disabled/ removed skim in 99 grand cherokee. It now runs with any key cut to fit. Alarm still flashes exterior lights. Don't have key fob anymore but want to disable Alarm now. Ideas?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MEGAN Jewell 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 210
总计 65,017
