跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
My xbox turns on then instantly off.
It has not water damage, psu issues, it has great ventilation, good power cord, and absolutely no reason to do this. It was running fine unplugged it for a day or two and came back to hit the power button it made the power up noise but no shut off noise, please help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you cleaned the inside of the console recently? Have you applied new thermal paste to the CPU recently?
完成的
@andrewsawesome yes, it appears to have no issues it has power running through the entire thing I have tested everything it seems to be fine
完成的
添加一条评论
1个答案
Hello there,
Please refer to a YT channel like tronicsfix as he specializes in this console repair business.
I will try and solve it here.
Firstly, have you tried checking your connections?
Please let me know how this goes
这个答案有帮助吗?
得分 0
2条评论:
Yes, everything has a great connection I hear I sort of popping noise where the thermal paste is I replaced it recently.
完成的
Next, can you check voltages across the board?
完成的
添加一条评论
添加你的答案
Trey Maines 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 70
