跳转到主内容
Repair and troubleshooting information for the HP EliteBook 840 G5, an HP laptop part of the HP EliteBook series. Released in February 2018.
My laptop brightness not changing by function key
My laptop brightness not changing by function key. Actually key is working but brightness adjustment not work by that
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
my fan key not working
完成的
添加一条评论
3个答案
最有帮助的答案
More than likely there’s a function key or a function lock which is on or stuck. Check in the lower left hand part of the keyboard for an fn key. Press and hold that and see if you can get the brightness to work. If yes, then function lock is probably enabled (some models have a light on this FN key to indicate this, but I don’t recall if this is one of them).
If there is a light, or it seems to be enabled. You can turn function lock off by pressing and holding the FN key and then pressing shift (which should say FN lock in the corner in addition to Shift).
这个答案有帮助吗?
得分 7
添加一条评论
Install HP Hotkey Support drivers .
这个答案有帮助吗?
得分 2
添加一条评论
Dear Rishabh,
You should download the display drivers and install them. After installation, restart your laptop. You can obtain the drivers from the HP website by entering your laptop model and selecting the display driver. Install it accordingly.
Best regards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rishabh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 20,450
