跳转到主内容
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
Why does my PlayStation 5 shutdown while playing games?
So my system will start up and run fine until i start a game then it last anywhere from 10-30 minutes, and with no warning just shuts down
Update (05/19/23)
Update it was an excessive heat issue I cleared the dust with a shop vac, now i keep it in a well ventilated area and it’s running like a champ, thank you all for the suggestions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
So update it was an excessive heat issue i used a shop vac and cleared the dust out, i now currently keep it in a well ventilated area and she runs like its straight out the box thank you guys for the suggestions.
完成的
添加一条评论
5个答案
最有帮助的答案
I have faced the same issues, keeping the console in well venitilated area, is very important. It worked like a charm, before I kept in a closed rack, since then I faced exactly same issues.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem, but it only turns off when playing ps5 games. (Ps4 games work fine). Did you find a solution?
这个答案有帮助吗?
得分 0
2条评论:
Please ensure your heatsinks and power supply vents are not full of dust, hair, or other debris. The PS5 is very sensitive to any blockages arising from poor maintenance and environment.
You might also have a liquid metal oxidation problem. How does your fan sound? Do you get overheat warnings? How's the power connection? At full draw, PS5s use up to 240 watts maximum. Best to plug into it's own dedicated outlet, and not use a surge protector if possible. Most home wiring if up to code, include ground wiring to prevent surges built into the outlets.
How long have you had the PS5? Is the issue new, old, worsening, or stable?
完成的
I have the same problem only turns off when playing ps5 game like Gran Turismo 7, Gran Turismo Sport is a PS4 game I play on my PS5 and the console have never shutsdown by iself playing that game. so I think its a problem playing PS5 games only.
完成的
添加一条评论
Ps5 isn’t coming on at all. Not making a sound. Is there any hope to revive it?
这个答案有帮助吗?
得分 0
添加一条评论
No warning shutdowns are usually indicative of either power failure or excessive heat. Now, as many have suggested try and keep good airflow to the airducts, and ensure that if you are a smoker (or have someone who smokes) that the fans are clean as the oils from the cigarette smoke can make dust get stuck on the fans preventing them from working well.
这个答案有帮助吗?
得分 0
添加一条评论
What happens if overheated?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Malcolm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 811
