跳转到主内容
The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
How to fix my power jack
I have tried to solder it back together but I am not sure if I have done it right can solder arc between it self as there is a small gap in the solder I did manage to turn it back on for a few seconds then it died then when I tried again there was a spark from the power jack
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
@andrewlang00 post some pictures of the jack and teh repair etc. with your question. Let's see if there was a solder bridge or similar that may have caused this. 在已经存在的问题里加入图片
完成的
@oldturkey03 added photos also I am very aware my soldering job is terrible hopefully the pictures help tho
完成的
It was fixed to the board better when I first tested it but taking it in and out has loosened the solder
完成的
添加一条评论
1个答案
已选择的解决方案
It looks like these are "cold" solder joints, which means the connection between the pad and the pins are not good, which would explain the sparking. Try to touch your soldering iron to the pin and the pad and the same time to heat up both and then apply solder so it covers the pin and the pad for a flawless connection.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Andrew Lang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 169
