跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
577 个问题 查看全部
a1278 No display, no wifi, no bluetooth
I have a unibody macbook pro a1278 which does not have a working display, Bluetooth or wifi. what could be the problem? The backlight and apple logo do not turn on.
  • display port output works (tested using mini-dp to vga adapter)
  • wifi - “no hardware installed”
  • LAN port works
  • no visible damage on motherboard components
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It might be the display has met liquids at some stage, both wifi and BT antennas are there inside within the display. You could remove the glass to see what's inside and in case try to replace the display. Heaven only knows if that will solve the issues as it's not so unusual shorts on the display may destroy components on the logic board too. Unless you have a microscope and testing tools "visible damage" may not be very meaningful.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thomas30man 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 88
