跳转到主内容
加入维修社区 - 创建账户
于2016年3月上市。型号 SM-G930V。
cant remove back plate
HI, I have followed the steps on the replace back plate instruction and for the life of me no matter how much I heat the phone I can not get the back to lift at all not even slightly i have tried heating to the point i need to hold the phone with a towel and tried to lift with suction cup but still nothing any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Have you tried to use a spudger and/ore opening picks to separate the glass?
完成的
添加一条评论
1个答案
Hi There,
With the back glass on this device, you need to use a lot of heat. I see in your post you tried this. We use around 60-80 degrees C on our heat pad then use thin metal cards to get under the glass. Once we have that in we switch to plastic cards and run them around the edge. The phone needs to be basically so hot you cant hold it.
Hope this helps.
Eric
这个答案有帮助吗?
得分 0
1条评论:
if you struggle to cut the glue at the plastic card stage you can apply some isopropyl alcohol to the card. Only a small amount though. you don't want it dripping into the screen.
完成的
添加一条评论
添加你的答案
Carla James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 364
