跳转到主内容
Model A1199 / 2, 4, or 8 GB capacity
85 个问题 查看全部
Why is there a "do not disconnect" logo on my screen
We just bought a used iPod and there is no booklet with it. When I plugged it in to my computer via a USB connector there is now a sign blinking and saying "do not disconnect". Is there a problem???
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
i am using 7th ipod nano and it says okay to disconet but it just stays there i tried reseting it and puting it on disk mode not of this worked
完成的
添加一条评论
7个答案
已选择的解决方案
it has a do not disconnect on it because your iPod is trying to talk to the computer. If you disconnect it without first removing it from the computers desktop you can corrupt both the iPod and the computer.
Go to : http://support.apple.com/manuals/#iPod and locate your iPod and download the manual.
Take care
这个答案有帮助吗?
得分 6
添加一条评论
最有帮助的答案
This is normal. There is not a problem. You simply have to go into your iTunes program and 'eject' the iPod. The eject icon is a triangle over a bar just to the right of where it lists your iPod on the left column in iTunes.
Roll your cursor over the triangle and press once. After just a couple of seconds, your iPod will be ready to disconnect and the "do not disconnect" logo will disappear.
Good luck,
Frank
这个答案有帮助吗?
得分 10
2条评论:
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the ipod icon goes away...this normal??
完成的
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the icon goes away...this normal??
完成的
添加一条评论
toggle hold switch 5 times, then hold center button and menu button at same time for 10-20 seconds. Sounds crazy, but it worked for me!
这个答案有帮助吗?
得分 4
5条评论:
Thank you for sharing this! It worked for me too! I didn't want to have to recover and reset it.
完成的
but this happens every time i connect it
完成的
Haha, now my ipod is sad. help
完成的
it happend every time iconnect it then how can down load music
完成的
Hey I did what you said and it worked right away. I really appreciate you doing this. So many people have different ways of doing things with Apple but they seem to work very well for me the first try out. You’re the greatest thanks again and keep adding comments and answers for any issues that come up with iPad Mac of any type and OS X programs. Thank you so much for your help
完成的
添加一条评论
@debbie
Make sure you use iTunes, and connect your iPod.
Select your iPod in the navigation panel on the left, Devices section.
Now use the Music button in the top menu.
Select to synchronize only "Selected playlists".
Only the tracks used in the selected playlists will be synced to your iPod.
The other tracks in your music library will not appear on your device.
这个答案有帮助吗?
得分 3
添加一条评论
Super,works like a charm!
这个答案有帮助吗?
得分 1
添加一条评论
I’ve tried everything and I cannot get the do not disconnect off of my Ipod. Please Help!!!!!! It doesn’t even show my Ipod Icon in ITunes…..
这个答案有帮助吗?
得分 0
2条评论:
exactly the same for me Carmelita !!!!
完成的
and for me, frustrating
完成的
添加一条评论
u need to disconnect! If the do not disconnect is still present, theoretically it will boot back into iPod software
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 39
过去 30 天: 135
总计 36,575
