跳转到主内容
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
67 个问题 查看全部
AirPods Pro LED indicator light, charging port not working.
Both the LED indicator and the charging port on my AirPods Pro case have decided to stop working. The sync button on the back of the case still works, the case still shows it charging the earbuds on the popup, and they still pair and connect to both my MacBook and my iPhone. The case charges wirelessly but the port does nothing. I’ve cleaned it a good few times and it still doesn’t work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Good evening from the down under,
If you're a skilled repair technician then go right on ahead and fix the port.
If your not though, you:
  1. Will be stuck using wireless charging forever
  2. Take it to apple and they will quote you an extortionate price for replacement
  3. Take it to a repair technician who will quote a more reasonable price.
这个答案有帮助吗?
得分 1
添加一条评论
changing point
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
the 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 1,423
