Seagate backup plus desktop drive 4tb turns on and off.
STDT4000100 Seagate backup plus desktop drive 4tb turns on and off while connected to my computer.
Probably a power supply issue. Just make sure the (12V 1.5A look on the label on yours) polarity is correct. You will usually see a little diagram with three cirlces. The first will have either a + or a - symbol with a line to the edge. The third will be like the first but with the other symbol and a line going to the black dot in the centre. If it is not the power adapter then the drive enclosure may be the problem.
这个答案有帮助吗?
It was the USB power-saving feature.
There you go Ben, a simple solution. Good one!
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 346
