跳转到主内容
加入维修社区 - 创建账户
Repair manuals for the HP Pavilion identified by model number: 15-d017cl.
Can replace this laptop's internal wireless card?
Having difficult time learning if the internal wireless card can be replaced or is it attached to the motherboard? I’ve tried 2 different USB wireless adapters but one they’re running, when I turn laptop off and back on—no Internet. Are ports too old to handle them? Thanks for any help you can offer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
First of all have you checked to see if the wireless adapter is showing up in the Device Manager in Windows Control Panel. If it is there but has a yellow exclamation mark then it is possible the driver is corrupted. Uninstall it and let reboot and let Windows automatically reinstall the driver.
To answer your question:
Yes it can be replaced and is not soldered to the motherboard. Gently pry off the black antenna connecting wire, unscrew mounting screw and slide card out of socket.
Here are the disassemble instructions:
HP Pavilion 15-d017cl Motherboard Replacement
The wireless card in circled in red in the first photo.
这个答案有帮助吗?
得分 2
2条评论:
Thank you! That’s a BIG help. Have a couple deadlines this week so may need to continue limping along til the weekend. But at least you’ve given me one more option to try! Your quick and knowledgeable response is much appreciated.
完成的
Oh, and yes, I did go to Device Mgr and first tried uninstall/install ... no luck. Thanks!
完成的
添加一条评论
添加你的答案
LinDee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 464
