My iPhone is water Damaged how can I fix it?
How can i fix my iPhone that is water damaged?
What gen do you have?
First, leave it in a bag of uncooked rice for a night- DO NOT TURN IT ON!
Then, try turning it on, if it doesn't, try replacing the battery, if that doesn't get it to work it usually means your logic board is fried, which isn't worth replacing.
If you specify which gen you have I can direct you to the parts necessary.
Search also these forums for the tag "liquid spill" and "water damage"
这个答案有帮助吗?
I have an iPhone 3G it was water damaged because i went in a water ride with it in my pocket by accident.
Have you tried anything I suggested?
I agree with rab.... Whenever a Li-ion Battery gets water intrusion, the battery is a goner.... Lithium in its natural state is HIGHLY reactive to water, therefore, you loose ALL charge and ability to recharge..... Replace the battery.... (Aviation Electrician - USN)
(Look on Amazon....I get batteries for cheap there)
这个答案有帮助吗?
they are cheaper on ebay... they are worth $10 each(chinesse but they work very well)
这个答案有帮助吗?
My daughter had water damage to an iphone 8GB. I was able to dry it out by warming the oven and alternating refrigerator. My question is: How do you separate the covers to get at the inside? I took the two little crews out of the top. I was then afraid to cause damage. I would like to know the dissasembly for the future.
这个答案有帮助吗?
you can click on any of the links at the top right of this page...the step by step guides, or on the home page click repair.
i wouldn't recommend the cooking or freezing method though. 1. you might melt an otherwise saveable phone, 2. water expands when frozen.. so you risk it breaking even more things. do what rab777 suggests, but better to clean with isopropyl alcohol.
I clean iPhones for a living and this is how you fix it.
Firstly, the longer the phone is left with water damage the harder it is to fix.
Take the phone appart, In order to do that you require a precision screwdriver set. Remove the screen and place the iphone into a Ultasonic bath containing methylated spirits and turn it on. Leave the phone in the liquid for approx 5 min. Remove the phone and allow the methylated spirits to evapporate.
Put the screen back on and all will be fixed.
Sorted.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,719
Too dry out my phone does it have to be white rice or does brown rice work just as well
由 jim 完成的
