跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
153 个问题 查看全部
Password digits 3,6,9,cancel not functioning
I replaced the digitizer about 18 months ago. It has been flaky ever since. I reopened it to see if I could fix this problem. Now the symptom is the digits 3,6,9,and cancel will not respond when opening password. This symptom is not now flakey but solidly not functioning. I thoroughly cleaned the connectors per your instructions. My question is, is it the digitizer or the processor. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hey Chuck,
Seems to me like a logic board issue as concurred by @beanman56 . With that being said maybe there are dead spots on the screen which are causing this.
Did this happen after an update or did something happen to the device prior?
IMPORTANT NOTICE:
From Sunday Aus to Friday AUS, i will be unavailable as i am camping then.
这个答案有帮助吗?
得分 2
添加一条评论
Its the digitizer
i’m 99.5% sure
这个答案有帮助吗?
得分 1
2条评论:
Replaced digitizer same problem.
完成的
Sounds like its a logic board problem then :/
Like the software or something
完成的
添加一条评论
添加你的答案
Chuck Porembski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 136
