How to fix iPhone 6s+ getting hot and not working
i have an iPhone 6s+ that is water damaged it use to have the vibration from the silence function work but now when i plug it in it does nothing except get warm on the top part of the logic board near the screen connections but when unpluged it deos nothing any way i can fix it this im trying not to have to buy new parts i have tried pluging it in to my chrome book but it wont show up but that’s probably bc its a chrome book
If there is liquid contact to board components it is possible they may have been damaged in a way where they would need replacement to function. No way to know for sure what exactly the issue is without opening the device up and having look. Check for any spots where water may have gone.
由 Alisha C 完成的
i have looked i found rust on some screws but thats it nothing else looks wrong just a lilttle dirty the water indicators have turned red but i only checked the one at the top i think there is more but idk where
由 keith_themuscovyduck 完成的
@keith_themuscovyduck I would take the whole board out. there's a guide here: iPhone 6s Plus 主板更换. And just look. Dirty could also mean corrosion. Some corrosion just looks like that. Take some pictures if you can and add them to you original post.
I will also add. Trying to fix this without buying parts is probably a BIG ask. Especially on a liquid damaged phone. It could be any of the attached components. Or necessary components on the board that are bad.
由 Alisha C 完成的
ok i will add some photo i do have a another iPhone 6 s plus that has a short in the logic board so I can use those parts
