跳转到主内容
Repair information for Sharp televisions.
105 个问题 查看全部
My TV has stopped responding to both my remote and onboard buttons.
My Sharp TV (LC55P6000U, G172055) suddenly stopped responding to remote commands with the exception of the power button. Now the onboard controls as well (except power). I did a hard reset on both the TV and the remote. It powers up, but if any button is pressed (whether remote or onboard) a spinning icon (waiting/busy/buffering) appears for a few minutes and then just disappears.
If I have my Xbox turned on, the TV will display it when powered up. But I can’t change volume or access menu etc… The remote has good batteries and the IR is working (checked through phone camera). I’m stumped! Is this a failing board? A known quirk?? Any help is greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
I am having same issue, did it fix for you? If yes, how?
完成的
i’m also having this issue. any fixes?
完成的
Must be common. Happening to mine too. Any suggestions appreciated. I feel I've tried everything.
完成的
Same problem just starting on Apr-30-2023. Any help? Leo Chapa.
完成的
@lodegariochapa same TV? Error like this is usually caused by a bad IR board.
完成的
显示更多的1条评论
添加一条评论
2个答案
最有帮助的答案
Hi @nickydanger ,
Try a factory reset and check if that works.
Take heed of the information at the top of the page about how doing this will delete all personal info, customized settings and installed apps in the TV and restore it to its factory default condition
这个答案有帮助吗?
得分 1
2条评论:
this is not working for me. i think since the tv isn’t responding to the onboard buttons, this is not a viable option for me. :( PLEASE HELP
完成的
Did you ever find a solution?
完成的
添加一条评论
Hello, I'm unsure if you still have your TV. Mines did the same thing the other day. I called customer service today which didn't help. My 20 yr. Old came in the living room while I was on the phone and said did you try to unplug the TV for at least 30 sec. I hadn't done so yet. I just messed with the remote and the TV bottoms. He unplugged it and it's working again.
这个答案有帮助吗?
得分 1
1条评论:
@neish52055
I do still have mine, but it still doesn't work. At first unplugging it did work, but it would stop within a few days. After the third time I was never able to get it to work again. I was quoted $200 from a local repair shop so I just went out and bought a hisense for less on black friday... it's a shame that it's uneconomical to keep old devices running but it is what it is I guess.
完成的
添加一条评论
添加你的答案
Nicholas Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 177
总计 4,208
