跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
new screen won't attach-- metal tabs broken off?
My son removed the screen on iPhone X (to replace battery) and broke the screen. So ordered a new screen, hooked it up, but when I go to reassemble, it doesn’t want to click-in to the phone body. I’m noticing the removed/broken screen has no metal tabs on the edges, but the new screen has several. Could these metal tabs be broken off in the phone body?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
More than likely when the screen was removed, the actual display came free from the frame it’s mounted to. Included images for reference of what the inside with no display should look like. The silver bit around the edge of the back of the display is likely still seated in the enclosure. You should be able to pop it out with a tool, just be mindful of the battery and other components. The clips just snap in place and will come free with enough force.
这个答案有帮助吗?
得分 3
4条评论:
This was exactly it. I was able to remove the bracket and attach the new screen. Thank you very much!
完成的
Thank you for this post!!!!
完成的
Yep, me too! Perfect!
完成的
@kcirsnurb Glad people are still running into this and finding it helpful :)
完成的
添加一条评论
添加你的答案
sethcrothers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 1,919
