跳转到主内容
The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26 个问题 查看全部
Which component is responsible for the network connection on the mobil
When I am connected to the Wi-Fi network at home, my OnePlus 6t occasionally disconnects from the Wi-Fi network and the mobile network out of the blue for about 20 seconds and then logs back in automatically. If, on the other hand, I switch off Wi-Fi and connect to the internet via the mobile network, the connection has never been interrupted. I have already reset the phone and during the set-up process the same problem occurred again, so it must be the hardware. My question now is, which component do I need to replace? Where is the antenna for the connection to the WLAN/mobile network, is it a separate circuit board or is it on the motherboard? It would be nice if someone could take care of me, as the problem is really annoying, especially when the connection simply drops out during a phone call. Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
WiFi signalling is handled by the WiFi/BT IC whereas GSM signalling is handled by a different IC.
Try using the phone as close as possible to the WiFi router (<30cm) and check if the connection remains stable.
If it does it may be a loose WiFi antenna connection.
Here’s the ifixit 一加6T主板更换 guide. It is useful as it shows how to open the phone so that access to the WiFi antennae is possible. Go to Step.11 to view one end of the connection. The other end is under the speaker, unfortunately not shown here
OnePlus 6T Speaker图片
指南
OnePlus 6T Speaker Replacement
难度:
中等
15 - 20 minutes
OnePlus 6T 主板图片
指南
一加6T主板更换
难度:
中等
40 - 45 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
OnePlus Nutzer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 146
