跳转到主内容
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
16 个问题 查看全部
Fiesta won’t start after battery change
After my daughter failed her driving test for the second time she lost hart hand her 61 plate fiesta sat for 3 months. When I encouraged her to try again the car would not start so I had to jump it. I replaced the battery a week later but now everything lights but the engin won’t turn over. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
simon croskery when you turn your headlights on and try to start the engine, do the headlights lights dim? Did you double check your work? All cables properly connected? Also, excuse my own ignorance but a 61 plate is a what year? 2011? I assume it's a UK model ;)
完成的
Yer 2011. Lights don’t dim. Just a clicks when you turn the ignition on. Battery was disconnected overnight when I went for the new one. Could it be immobilised?
完成的
@simon.croskery let's see what we can find out. I do have the manual for the US model but it does seem to e considerably different. Let me check for the European.Model. Yes, it is possible that this is related to the immobilizer system since it detected that the electrical system was "tampered" with. Does the immobilizer light flash or any other indication? Hopefully you can resolve this without having to have the key reprogrammed etc.
完成的
添加一条评论
1个答案
What good, I had this problem too its because they limit the access to your festia. So never get a festia again lol! So mine was beacuse i unplugged the battery and it would not start once i contcnted it agian. WHat you have to do is find a code for your car. This is a secutry code. YOU HAVE TO TYPE THE CODE PERFECT WHILE TURING THE KEY TO START THE CAR. its has to be super perfect. I got upset about it. And ford would not take it off. I went under the wheel and manually unplugged
这个答案有帮助吗?
得分 0
1条评论:
My ford overheating how to fix that
完成的
添加一条评论
添加你的答案
simon.croskery 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 86
总计 367
