跳转到主内容
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
Why cant I remove write protection how to reinstall firmware
I have a sandisk usb drive but I can’t remove write protection I tried diskpart and registry and neither worked. can I fix it? UPDATE: I think i need to reinstall the firmware how would i do that and how to back up my existing firmware
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
21条评论
I added more pictures
完成的
what do i do now?
完成的
@iliketechalot
Hi John,
You didn't answer the question "Is there data you need to recover?".
If not use "USB Drive Factory Reset Tool v3.0"
https://usb-drive-factory-reset-tool.upd...
Did you run the freeware "EaseUS CleanGenius"?
https://www.easeus.com/storage-media-rec...
完成的
there is no data to recover and I tried both tools neither one worked
完成的
no they just did not work
完成的
显示更多的16条评论
添加一条评论
3个答案
最有帮助的答案
Open it up. The rattling may be the right protect switch has come loose.
Here is a software option. There are others.
If you don’t have any important data on it just reformat. USB Drive Factory Reset Tool v3.0 is a good one.
More. . .
@iliketechalot
You'll have to do the leg work. Re: partition managers newer freeware versions may not have all the full capabilities of older ones. This site archives some of the previous versions http://filehippo.com/ Look around.
ChipsetGenius will give you the flash drive chipset and firmware versions details - use an on board USB 2.0 port directly (not an external Hub).
Here is an example output from ChipsetGenius:
"Description: [I:]USB Mass Storage Device(USB3.0 FLASH DRIVE)
Device Type: Mass Storage Device
Protocal Version: USB 2.10 <- Hint: This device can run faster when plugged to a USB3.0 port (Note - would NOT work from my USB 3.1 ports)
Current Speed: High Speed
Max Current: 300mA
USB Device ID: VID = 1005 PID = B128
Serial Number: 0703677A1B7B1768
Device Vendor: USB3.0
Device Name: FLASH DRIVE
Device Revision: 0100
Manufacturer: USB3.0
Product Model: FLASH DRIVE
Product Revision: PMAP
Controller Vendor: Phison
Controller Part-Number: PS2251-07(PS2307) - F/W 05.01.10 [2016-03-16]
Flash ID code: 983A94937651 - Toshiba [MLC]
Tools on web: http://dl.mydigit.net/special/up/phison.... " Mainly in Chinese but utility names are in English so cut and paste and do google search.
So you see it gives the controller brand, part number and firmware version. Cut and paste the results into a text file for reference.
This is a good site.
http://www.flashdrive-repair.com/
Remember the firmware must be exact. You will have to search yourself. If you are not having fun here I would suggest dropping it and moving on. You have to have a curiosity with a passion to investigate this kind of stuff. If you do please keep me posted on your progress.
这个答案有帮助吗?
得分 3
3条评论:
how do I take it apart?
完成的
@iliketechalot
Hi John,
Just GENTLY pry it apart using your finger nail, a small artist spatuala, etc. Most important take your time and enjoy figuring it out.
完成的
I've been very busy lately so I will do this later probably in a week or 2 I will keep you updated
完成的
添加一条评论
I have the same problem. Same, it is a Sandisk Cruzer USB. It happened suddenly, 1 day I decided to format and hope , enable to write, or write protected.
During my research peoples, I read that it happen after using something like secure vault, or dont know what. but I never used that $@$* secure vault or dont know what provided by Sandisk.
Another reseach told me that those Cruzer USB are faulty and should be sended back, they gona provide another one.
Except warranty is gone + in my country no warranty disponible or Sandisk store.
I tried everything, even GParted through DOS. Nothing works!!
Never ever buy again a Sandisk or Cruzer product!! Luckily there is no data on it.
My best guess, internal software need to be flashed back, with something through DOS, not through Windows, cause Windows is very poor for managing other devices than itself. Maybe by Linux. Unfortunatly I could not find anything over the net for this problem, most people say it is locked by the small Switch present on the USB, except there is no switch!
这个答案有帮助吗?
得分 0
添加一条评论
I know this is over A year old but if you want what seems to be the best drive software that fixes everything from flash drives to floppy drives, hard drives to solid state drives check out spinrite from steve over at gibson research. Here is the link. https://www.grc.com/spinrite.htm
这个答案有帮助吗?
得分 0
1条评论:
Thank you I will try this if I can find the flash drive again lol
完成的
添加一条评论
添加你的答案
john 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 59
总计 3,603
