跳转到主内容
The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
Would this game gear work with new capacitors?
I am wondering what is wrong with my Sega Game Gear and if it would work with a new screen and capacitors. Looking at the pictures the only thing wrong with it is the picture has bars in it and some of the parts in the lower right and left corners have some brown stuff on them. Also one of the pictures shows a exposed wire and I am wondering if this has caused damage or if I just need to add some tape on it. You can see the game play on the screen from a angle from the bottom but the top part of the screen is blank.
-Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@kwjameblond could very well be. "have some brown stuff on them" that is the first thing you want to clean. I'd remove the board and clean it with some high grade isopropyl alcohol and a soft brush. Looks like a bit of liquid damage or some sticker goop which may just shorten out the contacts. So, don't use it or power it up but clean it first.
Measure the wire with an ohmmeter and see if you have continuity. If so, put some electrical damage around the damaged area.
完成的
添加一条评论
1个答案
最有帮助的答案
The fact that you can still see the game is probably a good sign.
I would give it a try since the game gear is infamous for various problems related to bad caps.
The brown stuff in the picture seems to be glue so don’t worry about that.
I would still clean the board when you take off the old caps since there could be electrolytic fluid that leaked.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kwjamesblond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 450
